Traction control off lamp is always on...
lowpost99
Lowpost99
Atlanta, GA
I think my traction control system is fouled up. The button doesn't turn the lamp off. Any thoughts? Anyone know how to troubleshoot the system and wiring/switch?
a tech2 will point you right to the problem, or any high end scanner that can read bcm codes like a snap on, otherwise unless you can see something broken then you are just guessing, could be several different things.
Drewphil
