TPMS Problem - Battery? 2009 Yukon
dro45
The TPMS light is coming on indicating a problem with my left front. The tire and pressure are fine. The light was off and on for a month or two, but is now on solid.
Given that the car is 10 years old, I'm guessing a battery problem. Are the batteries replaceable?
Thanks for any advice.
You're lucky they usually only last 6-7 years. No, the batteries are not replaceable. Do them all at once to save money.
Now, the light comes on, does the pressure on the dash for that tire read dashes or a crazy number? Or is the number normal?
D
dro45
The pressure for the L front is dashes. All others read correctly.
I agree that I'll replace all 4. Leaning toward just having the dealer do it, as opposed to buying the sensors and having Discount do them. My thinking is if I get them done at Discount and one or more won't program, then it will be a mess to take them off and return them, like to Amazon.
Just buy ACDelco sensors and have a tire shop do it to save money. They will program for sure. Stay away from the cheap aftermarket sensors.
D
dro45
Agreed. For sure, I wouldn't try any cheapo replacements. Given the way there are knockoffs for about everything, what is the best way to make sure it is genuine AC Delco and not just a knockoff duplicate even including the logo?
Wolfbraid
Winston Salem, NC
Do make sure you get the correct ones, IIRC there are two versions that transmit at different frequencies
Price. And buy from a reputable company. Look at their reviews. If it seems too cheap or too good to be true or there’s no reviews, stay away.
We had a list of known part numbers on here somewhere. 13598771 are in mine now, they are from a 2016 takeoff. 25920615 were my old ones which lasted 7 years and 2 months.
D
dro45
Just to follow up, I ended up driving into Discount Tire. They quoted me $60 per tire, parts and labor, using the VDO redi sensor. The total was about $200 less than the Chevy dealer, so I went for it. While doing the work, they found a screw in my LF and fixed that free. The sensors are working well and if I do end up with a problem, I only have one outfit to deal with.
Thanks again for all the good advice.
Laurents10
