Tire size
benyay
Im putting a 3 inch lift on a 06 tahoe rwd and was wondering what tire size i should go with
Big Mama
Virginia
Welcome to the forum from Virginia. Some of the lifted guys will chime in. How big are your wheels? What kind of driving do you do?
Trey Hardy
Eastern North Carolina
Stock wheels you could clear 35s with a lil trimming and torsion keys turned up
If your worried about scrubbing or don’t want to trim your valence get 33/12.50s and you’ll be good to go!
GregBunney
If you’re worried about scrubbing or don’t want to trim your valence get 33/12.50s and you’ll be good to go!
Just ordered some 33x12.50 17 Falkens and I’m installing my leveling kit this weekend. I thought i read I might need spacers somewhere? Is this true? Mines a 4wd, idk if that matters much for this lol
Trey Hardy
For the stock rims you may need .25” spacers at a minimum to keep the tire from rubbing on the upper control arms at full lock but I feel like that was mainly for larger aftermarket control arms if you run into a issue with that you can get some from advance auto fairly cheap
Vzepeda
