Throttle body help (solved)
pauly1119
I changed my throttle body sensor today and then turned the key on and pushed the gas pedal to wipe down the inside of the throttle body but the door wouldn’t open. I gently pushed it open but was pretty hard to open but it finally kind of popped open. I didn’t spray anything inside just wiped it down. Put it all back together and now I’m getting a reduced power and running very rough. I tried for it to relearn but it won’t do anything. It’s hardly running now. Disconnected the battery and tried it all over again and still nothing. It was actually running great before I started. 2001 Yukon XL
what exactly did you change? the whole throttle body or some attached part?
P
pauly1119
Just the throttle sensor. I’ve cleaned it before but the door always opened when I pressed the gas pedal. This time it wouldn’t open. I may have damaged that part that opens it now? I may just order a whole new throttle body assembly complete but they are expensive
I would open it up and see what happened inside, not sure why you are pressing the gas pedal the cable lever is right there with the cable on it and spring retention.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yea, it is cable actuated instead of "drive by wire" design. Time to go back and check your work. By "throttle body sensor" do you mean the TPS- "Throttle Position Sensor"?
P
pauly1119
Okay here are some pics
if you had to force it open then it's possible, I would guess unless you can see something in there that doesn't look right and correct it then I don't know.
I would use a flashlight and see if maybe a metal tab got pushed and bent or anything like that.
That's what happens when all the info is not given. Got the year and the model but no engine size. That is a very very rare drive by wire if in fact it is. 2001 is a cable vehicle. Gonna wait till I know for sure.
P
pauly1119
It’s a 5.3 and it’s definitely not a cable driven throttle.
Charlie21ny
