The twin hoes plus one
Sparksalot
Bastrop County, Texas
I had a serendipitous chance to snap the twins together this afternoon.
For now anyway, Lola has a white hood.
Sparksalot
Sparksalot
Lola got a new switch for the hatch glass release. Even though I had watched videos, it was still pretty fiddly to remove the old one.
I also removed the remnants of the highway patrol emblems. Oooooooo.
D765AA32-FFC0-4369-AE43-84FC7BBD88E6.jpeg 07F6F7D0-00B4-404F-9BAD-B11656CAE256.jpeg C2137D1E-6CC8-4AD4-A7CC-E5EB126F0AFC.jpeg
Sparksalot
Sparksalot
Not to leave thecopcar out. Knowing the rear hatch release could fail at some point, and I have the weapon locker in the way, I’ve been planning ahead. The mounting bolts can be removed from underneath the body, and the front edge. I predrilled the hole in the lift gate panel to be able, with minimal fuss, release the hatch manually.
Sparksalot
Sparksalot
Since the rear seat is totally gone from thecopcar, I’ve been considering a platform to raise the floor level to be even with the Frontrunner water tank. Storage would go beneath. Options might include using ammo cans. Here’s a howitzer shell can set in place. A pair will fit back to back and could be easily flush with the water tank. Other options include 40mm and 60mm cans.
Sparksalot
Sparksalot
I know have the build sheets for both of the Hoes. Interesting weight numbers.
Thecopcar is listed as 3,042 lbs.
Lola is listed as 3,087 lbs.
I'm thinking I know they are supposed to be svelte, but I'm not sure by that much.
Sparksalot
Sparksalot
Build sheet for Lola. Hmmm remote start prepared...
Vehicle Build
Model: CC10706 - 2013 TAHOE 1500 2WD Order Number: QXPGPF
Gross Vehicle Weight: 3,087 Build Date: 05/17/2013
Build Plant: R
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
01U - SPECIAL PAINT
19C - EBONY
19I - EBONY
1FL - POLICE VEHICLE PACKAGE
1LR - CITY BRAKE
1SZ - MARKET PACKAGE IDENTIFIER
5T5 - SEO - VINYL REAR SEATS WITH CLOTH FRONT SEATS
6DA - COMP FRT LH COMPUTER SEL SUSP
6J1 - WIRING PROV,IGNITION & MAIN PWR
7DA - COMP FRT RH COMPUTER SEL SUSP
9N5 - SEO - FLOOR CONSOLE, DELETE
A31 - POWER WINDOWS
A95 - SEATS, FRONT BUCKET
AG1 - SIX-WAY POWER DRIVER SEAT
AG2 - PWR SEAT ADJUSTER, FRONT PASSENGER
AJ1 - DEEP TINTED GLASS
AJ7 - SIDE IMPACT AIR BAGS
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AM1 - MANUAL LUMBAR, DRIVER
AM8 - 2ND ROW BENCH
AP8 - REMOTE VEHICLE STARTER PREP PKG
ARL - PLANT CODE-ARLINGTON, TX
ASF - HEAD CURTAIN SIDE AIR BAGS
ATD - 3RD ROW SEAT DELETE
AU3 - POWER DOOR LOCKS
AXP - MPV VIN IDENT POSITION
BD2 - ORNAMENTATION DELETE
BG9 - RUBBERIZED-VINYL FLOOR COVERING
BVE - ASSIST STEPS
C25 - REAR WINDOW WIPER & WASHER
C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5U - GVW RATING - 6,800 LBS
C69 - AIR CONDITIONING -FRONT & REAR
CJ3 - AIR CONDITIONING TRI ZONE MANUAL
DH6 - LIGHTED VISOR/VANITY MIRRORS
DK8 - DELUXE OVERHEAD CONSOLE
DL8 - DUAL PWR HEATED OSRV MIRRORS
DNS - SUPPLIER INSTALLED EQUIPMENT
E2C - ORDER TO DELIVERY - EXPEDITE
E52 - LIFTGATE/LIFTGLASS
EF7 - U.S. COUNTRY CODE
FE9 - FEDERAL EMISSIONS
FHS - VEHICLE FUEL GASOLINE E85
FLT - FLEET PROCESSING OPTION
G80 - LOCKING REAR DIFFERENTIAL
GU4 - REAR AXLE 3.08 RATIO
JD9 - BRAKES, 17" DISC/DISC
JL4 - STABILITRAK-STABILITY CONTROL W/ TRACTION CONTROL SYSTEM
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
K5T - BATTERIES, DUAL
KC4 - ENGINE OIL COOLING SYSTEM
KNP - HD AUX TRANS. COOLING SYSTEM
KW1 - 160 AMP ALTERNATOR
LMG - ENGINE: VORTEC 5.3L SFI V8 WITH ACTIVE FUEL MANAGEMENT & FLEX FUEL CAPABILITY
MYC - TRANSMISSION: 6 SPEED AUTOMATIC
NK5 - STEERING WHEEL
NT7 - EMISSION SYSTEM FEDERAL TIER 2
NZ4 - SPARE WHEEL, 17" STEEL
PPV - POLICE VEHICLE PACKAGE
PZZ - SKID PLATE
QAR - 17" ALL-SEASON POLICE TIRES
QV9 - 17" STEEL WHEEL
R6D - FLT-BID ASSISTANCE/CE
R8C - TEXAS ID.
R9N - PROCESSING CODE
R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SAF - SPARE TIRE LOCK
T74 - HEADLAMPS
TGL - SEO - TWO TONE SPECIAL PAINT
TL1 - GRILLE
U2J - XM RADIO DELETE
U84 - ANTENNA
UE0 - ONSTAR/BLUETOOTH DELETE
UJM - TIRE PRESSURE MONITOR SYSTEM
UN9 - RADIO SUPPRESSION
UQ3 - ENHANCED AUDIO SPEAKERS
US8 - AM/FM STEREO, CD PLAYER, RDS
UT7 - AUX ELECT SYSTEM
V08 - HEAVY-DUTY COOLING
V76 - FRONT TOW HOOKS
V8D - VEHICLE STATEMENT
VGD - BODY COLOR FRONT FASCIA
VGE - BODY COLOR REAR FASCIA
VK3 - FRONT LICENSE PLATE MOUNT
VPV - SHIP THRU FREIGHT (KERR)
VQ3 - FLEET ORDERING AND ASSISTANCE
VT7 - OWNERS MANUAL ENGLISH
X88 - CHEVROLET CONVERSION
XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE
YD3 - BASE AXLE
YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING
YE9 - LS TRIM
YK6 - SEO IDENTIFICATION
Z56 - POLICE CHASSIS PACKAGE
ZAK - 17" BW SPARE TIRE
BadDaddy2003
