Supercharger
2005SnowKon
Fort Collins, CO
Thinking about getting a supercharger for my 2005 yukon. its got about 87K on it so why not. Going to sell my 2007 Suzuki LTR 450 to be able to afford it. What would you guys recommend. I personally like the way a Magnacharger looks on top of a motor, but a Vortex is alot cheaper by almost 2K
03tahoe2012
Plano,TX
WHEN <-----key word!
i do get a super i will deffently save up for the mangna! it looks so much better!!
2005SnowKon
2005SnowKon
Fort Collins, CO
yes "When" is key word but i do think that once the riding season gets closer i should be able to sell it quickly. I think the Magna would be the best bet also. Anything internally i need to worry about when i put it on.
ATL
i like the roots style blowers like the magna, but i thnk i would go with a centrifugal. positive displacement blowers(roots style) can make good power but they are very limited by the blower housing. a quality centrifugal blower like the procharger d1sc would be able to make all the power you wanted. they blower housing does not limit their output, so they can make waaaaaaay more boost.
each have their pros and cons, and your decision should be based off of your goal with the truck. are you trying to go offroad with the truck? you lookin to make it a street beast? just want alittle more power just for the fun of it? how much power are you hoping to make? are you running a 5.3? 6.0?
ATL
well it depends on the motor and mods of course. the lower the compression, the more boost you can run. if youre trying to make all the power you can and are running lower ompression, a nice centrifugal will be able to make 30+ psi of boost. i dont recall ever seeing a roots style making over 20 psi(except top fuel dragsters running like 12-71s). the amount of boost a roots can make is determined by the housing size, it can only move so much air. but because the design of centrifugal blowers, the limitation is impeller speed and bearing wear. of course centrifugals do come in different housing sizes as well, but think of a centrifugal as a belt driven turbo. the faster you spin them, the more boost they make. because it is power by a belt instead of exhaust gases, it doesnt have the same "lag" but does make very linear(rpm based, more rpm=more boost) power.
best way to explain the difference; roots boost is determined by throttle positioning, centrifugal boost is determined by rpm.
2005SnowKon
2005SnowKon
Fort Collins, CO
its going to be a sleeper is my goal for it. The only off roading it will be doing is when i go camping up in the mountains.
Time-Pilot
