Suede door panel accents
2LOUD4U
there is no need to remoce anything you use a strong 3m glue and have funn tucking i actually used a flat head screw driver i had the tool but i founf that it was eaier to do with the flat head fatnlow your gonna love it get up and do it!! haah jk
thehoe92
fo sho
The916
tahoe center console :)
2LOUD4U
haha wow kasey thats hott i didnt go that crazy but i did the seat belt covers
NJ04HOE
Paterson, NJ
damn, looks like im on the hunt for a denali armrest. other than the hole should a denali armrest bolt right up to mine?
Gjam - read the rest of this thread. a couple of use discussed the door panels in detail. they are a pita but it can be done and looks good.
Your gonna have to replace the entire console.....the lids aren't interchangeable, I ended up finding a denali console on ebay swapping it then selling my original console.
Narco
Narco
Atlanta
shit...guess ill just try and wrap mine. or send it to kasey and let him wrap it for me! :)
2LOUD4U
yahh narco thats prob a good idea is came out really good
thehoe92
fo sho
The916
send suede and glue with your console and I'll do it :)
dead serious haha I think its easy just time consuming but I always love seeing the end result
I was going to get a denali console too and doing vinyl on the bottom carpet and suede on the top plastic but I just grew a pair and wrapped my center console
2LOUD4U
haha yahh it does it looks clean mann looks like two 17 year olds are pretty good with the suede lmao
slocaddy
sarasota fl
hey kasey, where did your material come from? how much a yard? doese it have any strech to it? also have any you guys seen the foam backed suede? btw, truck looks sweet
2LOUD4U
i got mine from joanna's lol for 18.99 i dont think there is a need for the foam backing it would be harder to tuck that prob for seats
slocaddy
sarasota fl
yea i used the same stuff on my t-top camaro headliner and came out good except around where it had to curve around and up and over the edge, and could not get any strech to make it look good. Ive found some that claims to be ''2 way strech'' (what ever that means ) but am wondering if its at the expense of being nice material? thanks for the response.
thehoe92
fo sho
The916
well I have 2 different kinds in my hoe right now
the stuff on my doors and air bag is from joanns and thats some pretty quality stuff I got it for around $12 a yard IIRC, like I said earlier in this thread just look in the paper or online for coupons they always have like 50% off coupons
the stuff I used on my center console, glove compartment, etc. is from distinctivefabric.com and the reason I bought it there was because it was 60" wide so I bought a bunch in order to do my headliner but I didn't feel comfortable doing my headliner at the time so I just started wrapping more random pieces in my car
I would not recommend that "suede" because it is REALLY thin and the glue soaked through even on the lightest spots but I was quick to wipe it with some paint thinner then dry it off and it was fine, and it also looks more like fleece and doesn't feel like suede
my buddy bought the foam backed suede from a different website and used it on his headliner and it looked great and was probably much easier to handle because the glue wouldn't soak through so easy
I'm going to be buying the same when I get some money to do my headliner since I already have the 3M 90 for it
puckhead
CO
When you do the head liner are you gonna just lay it over the current head liner?
And did you have any trouble with creasing around the corners and curves at all? if that makes sense. like on the center counsel. great thread by the way!
thehoe92
fo sho
The916
yeah just over the old stuff, I have read on how to do headliners on just about every site, and it really depends on the quality of your current headliner
I should have taken more pictures but the whole center console just comes apart so there are a few pieces to wrap but the hardest one was the piece below the cupholders and behind the slots because they had such drastic curves
the trick is to let the glue work for you, get it tacky and set it in the curve first and work your way around that
viximaging
Houston/Spring
how do you remove the bose grills? I have some suede left and thinking of tackling this weekend. want to paint the grills
2LOUD4U
when you remove the door you will see the grill had little tabs on the back side and you just bend them straight and your good should pop right off
Narco
Narco
Atlanta
yup, speaker grills are easy to remove but you gotta take the damn panels off for it
vsaravia
