First, the 99 auto4wd are no longer decode by shorting terminals like the non-auto electric shifters. You need a qualified scanner which will give you the code on what is wrong specifically. If you have it in 2wd then leave it that way until you are sure what is going on. If your front actuator assembly was not working fully the TCCM would have tried to back out of 4wd after about 30 seconds. and not get stuck.
Here is some data but the error code would be best.
NVG 236/246-NP8 (Two Speed Automatic)
Transfer Case Shift Control Module
The transfer case shift control module uses the VIN information for calculations that are required for the different calibrations used based on axle ratio, transmission, tire size, and engine. The system does not know which calibration to use without this information.
The direct battery supply line (CKT 1640) provides the power to the module and motor circuitry.
Transfer Case Encoder Motor
The transfer case encoder motor consists of a permanent magnet (PM) DC motor and gear reduction assembly. It is located on the left hand side (drivers side) of the transfer case. When activated it turns the sector shaft of the transfer case (clockwise or counter clockwise) to shift the transfer case. The encoder motor is controlled with a Pulse Width Modulated (PWM) circuit within the transfer case shift control module. This circuit consists of a driver on both the Motor A and Motor B circuits. The encoder motor is bi-directional to allow the motor to shift the transfer case from 2HI or 4HI to neutral and 4LO positions.
The encoder is mounted to the transfer case encoder motor assembly and is replaced as an assembly. The encoder converts the sector shaft position (representing a mode or range) into electrical signals inputs to the automatic transfer case control module. The module can detect what position the transfer case is in by monitoring the 4 encoder channels (P. A, B. and C). These inputs translates into AUTO, 2H 4H, Neutral, and 4L or in transition between gears.
Transfer Case Motor Lock
The transfer case motor lock is used to provide a 2H, 4H, and 4L lock-up feature. When the lock circuit is energized, the transfer case encoder motor is allowed to turn. When the transfer case is placed 2H, 4H, or 4L the motor lock circuit has no power provided to it and the lock is applied.
This assures that the transfer case remains in the current gear position. When AUTO is selected the motor lock remains applied until an adaptive mode (torque is applied to the front propshaft) is required. During an adaptive mode the motor lock circuit is energized and the motor lock is released, enabling the encoder motor to turn and apply torque to the front propshaft.
Transfer Case Speed Sensors
There are three speed sensors on the Automatic Transfer Case (ATC) , two on the rear output shaft and one on the front output shaft. Each speed sensor is a Permanent Magnet (PM) generator. The PM generator produces a pulsing AC voltage. The AC voltage level and number of pulses increases as speed increases.
Vehicle Speed Sensor
One of the two on the rear output shaft is the vehicle speed sensor (VSS) input to the powertrain control module (PCM). The PCM sends this information to the transfer case shift control module via the Class 2 Serial Data bus.
Rear Propshaft Speed Sensor
The automatic transfer case control module converts the pulsating AC voltage from the rear transfer case speed sensor to a rear propshaft speed in RPM to be used for calculations. The rear propshaft speed can be displayed with a scan tool.
Front Propshaft Speed Sensor
The transfer case shift control module converts the pulsating AC voltage from the front transfer case speed sensor to front propshaft speed in RPM to be used for calculations, and to monitor the difference between the front and rear sensor speed. It is also used in the AUTO (Adapt) mode of operation to determine the amount of slip and the percent of torque to apply to the front axle. The front propshaft speed can be displayed with a scan tool.
SERVICE indicator (4WD/AWD) Lamp
The SERVICE indicator (4WD/AWD) lamp is an integral part of the cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the Automatic Transfer Case (ATC) system. The SERVICE indicator (4WD/AWD) lamp is controlled by the transfer case shift control module via CKT 1567.
---------- Post added at 05:12 PM ---------- Previous post was at 05:02 PM ----------
BTW have you checked for any blown fuses yet?
