Strange problem
ntxstallion
I installed a denali console in my reg yukon today. I was tapping the lines so that all of the cig lighters would work. I tapped the first one and it worked fine. I then tap the second and have lost all power. Even to the first one that I tapped. I checked all of the fuses and none are blown. What could be causing the problem. I did not touch any wires and all of this was done with the battery cables disconnected. This one is really stumping me.
Rivieraracing
Are you cutting and splicing or are you using the quick taps to get your power?
N
ntxstallion
Using quick splices cause I did not want to cut factory harnesses and I am tapping the from the original cig lighter connectors that were on the regular console.
Smokin Denali
