starter problems
willxfs
My rig is a 1998 2 door 4wd with about 250k on the clock. About a year ago I had my original AC Delco starter rebuilt at a shop in my town, changed the solenoid too. It was turning over at about half speed. Shop said many of the welds on the comm were broken. Worked great for a year. Now a year later the starter grinds on the flex plate but only every once in a while. Maybe once every three or four days. Sounds just like when you turn the key to start when the engine is already running. It always starts fine on the next turn of the key. Any ideas?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the sliding drive system on the start may just be getting stuck on its shaft from dirt and debris. you could try disassemble to clean it up and maybe lube it.
W
willxfs
Thanks. Will give that a shot. Wondering that while I have the starter down if it would be advisable to inspect the flex plate teeth. I'm sure I'll have to pull the spark plugs and turn the motor with a wrench to do this.
W
willxfs
Here's an update. The starter grinding got very infrequent for a while. Now a year later, it grinds almost once per day. I bought a new AC Delco drive/pinion gear/bendix for the starter. I installed it and lubed up the shaft. Starter is still grinding on the flex plate. I also put on a spare solenoid that I had from a while back-AC delco part. No luck. Still grinds once per day now.
As a side note, when I broke the starter down, the commutator I thought was replaced two years ago because of broken welds where brushes touch the comm, looks old as shit. It spins over great. The brushes look new. Any thoughts.
In retrospect, I should have bought a bran new AC Delco starter from Amazon for 110 bucks two years ago. At least I would know that its probably not the starter screwing up. Now I'm out $75 for the starter repair two years ago, $40 for a new solenoid two years ago and $40 for the new bendix last week. Still cant say for certain if its the starter or fly wheel teeth causing the problem. Crap! Any advice?
W
willxfs
Fixed starter
Here's an update. I fixed the grinding starter problem. It ended up being a worn out shift fork/lever.
GMT800 2005 Tahoe Z71
Navy Supporting Member
You are still going to want to inspect the teeth of the flex plate for any damage. If there is damage then that can damage the gear on starter over time. It takes to sets of teeth to make a grinding noise.
W
willxfs
Yeah, teeth on flex plate are fairly beet up from all the grinding. I'll definitely replace the flex plate in the near future. Thinking of pulling the old worn out 350 with 260k on the clock and going with a new one from jegs.
ScottS-Michigan
