Size of tires
Jmath
Hi,I'm wondering what's the biggest tires I can run on my 2000 z71 tahoe older body style I know the wheel size is 16x7 and I will be using the stock wheels and don't want to add any lift level or do any modifications I'm wanting a bit more of an aggressive look using A/Ts if anybody can help me out it would be appreciated Thanks in advance
drakon543
im using 265 70 17s fill the wheel well nicely but isn't too stuffed. i think you can run a 285 if im not mistaken
Martinjmpr
Littleton, Co
I think you can run 285/75/16's but might rub a bit on the front. I am running 285/75/16's on my '04 with Z71 springs in the rear and a T-bar leveling kit in the front with Bilstein 5100's on all 4 corners.
I thought Z71's all had 17" wheels? Are yours the "snowflake" pattern? If so, I'm pretty sure those are 17's not 16's in which case the equivalent size would be 285/70/17. IIRC factory Z71 tires were 265/70/17.
HiHoeSilver
Away!
Chicago
His is 2000. That's OBS. Wheels are the diamond cut star 16s.
HiHoeSilver
Away!
Chicago
Just for reference, do you have pics of this setup?
J
Jmath
My Tahoe is the older looking body more square it currently has LT265/75/R16
BeenChevy
Minnesota
You could achieve what you're going for with a set of Goodyear Wrangler Duratrac's.. or even some BFGoodrich T/A KO2's.
Measure the height of your current tires and run the tire size comparison tool: https://tiresize.com/comparison/ and measure for yourself. - you might be able to get away with 285/75/16 but like others have mentioned, you'll probably rub when turning lock:lock - especially in reverse anytime the suspension is at the right pitch. Good luck let us know what you go with.
Have a tire fettish and would otherwise recommend a 17"+ rim to open up your options.
J
Jmath
Ty very much I will keep you posted
Martinjmpr
Littleton, Co
drakon543
stickers! that thing must be a beast got like 100 extra hp with all those stickers:p
Jacob Metz
Weslaco, Tx
I’m currently running 35x12.50R20s with factory suspension on my 2001 Tahoe 4x4 non Z-71
JPeter
