shaking...... really hardddd........
03Yuk0n
hey guyssss..... my yukon 5.3l flex fuel always seems to start shakingggg like crazy when going above 70 mph. have any of u guys gotten this prob, n how did u guys fix it
thanks guys
bigshoes
hows you alignment and hows the balance on your wheels? Ujoints good?
Good be balancing issue, ball joints, u-joints,...
fire730
Louisiana
Since you have aftermarket 22s it's probably a balance problem.
electro
Kitchener, ON, CAN
You should look on each rim for weights.
On a nice set of show rims, the weights should be in on the back side or on the inside of the rim.
There SHOULD be a weight on EACH rim.
If there is a rim without a weight, I would have it balanced. Weights can fall off so if there is one rim or two rims without any weights well than perhaps they have fallen off.
Its easy to check for weights and its relatively inexpensive to have them put back on, so I would say thats a good place to start.
bigshoes
Another and I know it's far fetched. Make sure all your lugs are tight. Heard of to many people driving with wheels that are not tourqed down.
03Yuk0n
03Yuk0n
Hey thanks guys im gonna take it to my mechanic and see if any of the things mentioned above are it. hopefully this gets done.
Conedaddy
