sagging leaf spring
wes3337684
The drivers side rear of my yukon is 2 inchs lower than the passange side. I need to replace the driver side leaf spring but to do that do I have to drop the fuel tank to get the front bolt out?
hassoun
Germantown, MD
what year is your yukon ?
---------- Post added at 10:49 PM ---------- Previous post was at 10:48 PM ----------
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Support the rear axle independently in order to relieve the tension on the leaf springs.
3. Disconnect the Real Time Damping (RTD) sensors (25 series utilities if equipped). Refer to Rear Position Sensor Replacement - Electronic Suspension - Left (15 Series) or Rear Position Sensor Replacement - Electronic Suspension - Left (25 Series) or Rear Position Sensor Replacement - Electronic Suspension - flight (25 Series) in Real Time Damping (RTD) .
4. Remove the trailer hitch if equipped. Refer to Trailer Hitch Replacement in Body and Frame.
5. Remove the fuel tank for left side applications. Refer to in Powertrain Management.
6. Remove the U-bolt nuts.
7. Remove the U-bolts.
8. Remove the spring spacer.
9. Remove the anchor plate.
---------- Post added at 10:50 PM ---------- Previous post was at 10:49 PM ----------
it looks like your have to drop the tank man!
hassoun
Germantown, MD
just make sure you have as little gas as possible. dont do like i did when i swapped my fuel pump at almost a full tank haha. was a ***** to get down and quarter tank ended up on the ground.
W
wes3337684
Yeah hopefully I won't have to drop it all the way just drop it a little or slide it over enough to get to the bolt. Do you thank I should replace both sides of springs at the same time so it rides level? Also new springs are $260 and the juck yard has them for $50 which is the best bet?
hassoun
Germantown, MD
i would go with two new springs man. you need both to level the ride and get the comfort. i would go with brand new! thats me. if you're right on money then i guess used would do it. but it'll be a matter of time before they go bad ?
W
wes3337684
Yeah your right but $260 a peice I'll have to look around and see if I can find them anywhere cheaper. Thanks for the help.
97yukon
baton rouge
if your looking for drop springs my bro has a set he rode on for less than a year...will sell for cheap...very cheap.
W
wes3337684
Thank you thats a good price. Is the left spring the same as the right? So I just order 2 of them?
TigerEyz3
Slow and Steady
TN
Glad 992dr posted up... I was about to drop the same link on ya. :D
Wes... the two sides are the same. Truth be told you'll get a better overall price (cheaper shipping) if you make two separate orders...just make sure that they know to make them separate. Only thing is that they may arrive at different times doing it that way.
992dr
Eastern N.C.
Robert beat me, lol.
Huh, I didnt know that about shipping. I do know the price went up since I ordered mine, way back when.
retorq
Kingman AZ
Call a local spring shop ... I bet they aren't much more maybe even less.
TigerEyz3
Slow and Steady
TN
If "local spring shops" are like the ones in my area, they aren't gonna do what a spring replacement will...
When I called around in my area, they were talking about rearching (shot-peening) and adding a leaf. This doesn't work well for towing applications as the spring will go back to the "memory" that it has stored. Not to mention the price was about the same as getting new springs.
---------- Post added at 09:42 PM ---------- Previous post was at 09:40 PM ----------
Sam,
I haven't replaced mine... don't think I need to now that I've done even more research - truck is still level (side to side).
W
wes3337684
I talked to a guy at a spring shop and he said that air bags are the best way to go. cause he said the leaf spring will sag again in a couple years. Anybody tried the Firestone bags he said he could get them for $260 thats what new springs cost. So I'm on the fence,s new spring or just put bags with what I got.
Eickybobby5050
