Rust at 1,500 miles?
glundblad
We traded in a 2002 & 2003 on a 2011 tahoe. We took delivery in about October. It had about 7 miles on it when we bought it. I have always liked tahoes.
Shortly after we had it, we noticed rust starting to form on the passenger side under the rubber door seal (actually, it is at the joint of the two seals). It probably had about 1500 miles at that time.
We took it to the dealer and they took photos. Today, I noticed it was doing the same thing on the driver side. It is now up to 3k miles and we are still running the factory oil. We followed up with the dealer and they said it wasnt covered under warranty and that they could arrange for us to get an estimate for repairs from someone.
The dealer in our town was recently bought out by a bunch of ****** so I really doubt they would fix it correctly even if they said they would.
Our salesman said it was because we live on a dirt road. It is a terrible dirt road too. The problem is the area that is rusting doenst get exposed to the road.
Can anyone offer any suggestions on what I can do to get it fixed? I assume GM wouldnt do anything about it either.
Gzes
the drifting 2dr
Wichita tx
holy crap rust? my hoe has 170xxx and only has a lil surface ruston the roof. u must live in the north. i would soda blast the part and then if it has eaten anything then i would bond n sand then prime and paint again. the best thing to do is get it fixed and move to tx:)
G
glundblad
I should have clarified, yes I am in Northern Indiana, Columbia City specifically. But it doesnt snow in October & November (at least not this year). It started to rust before it snowed.
The last two lasted for a very long time. Rust was starting to form in the door seams on the '02 but none on the '03.
THE YETI
Director of Operations
South FL
hit up the GM Reps on this site, they have an 800 number they can have you call and get that fixed under warranty ASAP!
Wow...that definitely should not be happening!!
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
i can see if the paint was chipped and exposed metal started rusting. But on a 011? i think there is a 7 year 100k warranty on corrosion defects.
OHSIXX
Milwaukee
Yeah that definitely shouldn't be happening.......mine is going on 7 years old and doesn't have a lick of surface rust.....can't say the same for the underbody though......damn salt........
LuSe4
Bleen Member
Michigan
That is a bummer. Have any pics of rust? I am curious to see what a rusting 3000 mile vehicle looks like.
G
glundblad
Could someone direct me on how to get in contact with GM?
What would motivate the dealer to not want to do the right thing? GM reimburses dealers for warranty repairs. I dont understand why the dealer would baulk at fixing it?
Any dealer would fix it under warranty. Correct? I wouldnt need to take it to the one I bought it from?
There's a user on here names GM Customer Service. Send them a PM and see what they can do. A lot of times they can talk to someone an get you fixed up :waytogo:
The Pawnbroker
Annapolis, MD
Please take a pic and post it. That would help a ton. Is this a painted area? Are you sure it's rust? I'm just curious. What did the dealer tell you? It is of course covered under your warranty. At this point, everything is covered. Did the dealer tell you that part was an unpainted surface or something? There are areas of metal that may show some surface rust that don't matter. The frame etc. But if this is a painted area and it is showing rust, it should be fixed. And yes, you can take it to any dealer you want to. Your warranty is good at any GM dealer.
Please update us.
G
glundblad
I wanted to give everyone an update on my rust problem. It may impact about everyone here. The dealer took a look at it.
It was definately rust. I cleaned it so I have no pics to post to the forum. The dealer removed the threshold on the passenger side to investigate. There is a metal clip that connects the joint of the weather stripping. That connector has surface rust on it at the front driver side and front passenger side. It is leaving a rust trail on the painted part of the threshold and down to the rocker. It shows up when I go through the car wash. If that rust trail is left alone, especialy underneath the plastic threshold, and out of visibiliy, it will cause the body to rust. You wont know it until it is too late.
They said they would order new weather stripping for the driver and passenger sides. If I dont hear from them soon, I will tear it appart and paint the part. Then grease it. I suspect a new one will behave the same way. It looked very easy to get to. Pop the plastic threshold off and pull the weather stripping appart.
I should point out to everyone this occured before my truck was exposed to the winter weather here. My truck is white. Any other color would probably conceal it.
---------- Post added at 05:58 AM ---------- Previous post was at 05:41 AM ----------
Oh, and Pawnbroker asked what the dealer said. I keep my vehicles for a very long time. The dealership is under new ownership and they have adopted a policy in the service dept where every vehicle needs to generate $200 in services ( at least that is the local rumor). So I wasnt really expecting much action and even if they fixed it, I couldnt count on it being done right. I got lucky since it wasnt really the body of the truck.
My plan was to take it to a body shop and pay to have it done right. My wife got a little hot over it. She called them. Initially, they told her "surface rust wasnt covered under warranty". Then they told her "stop by for an estimate". Then they claimed it was a misunderstanding and that it would all be covered under warranty. But if surface rust isnt covered and they use the term estimate, I see no room for a misunderstanding. She called them ******. :)
When I do the math, I think they were expecting to get paid something from me to fix it. Since it is now a simple part swap, I dont think they are.
edgaranah1
Corona California
Dam stealerships. they probably wanted to charge u and GM for fixing it.
Sent from my iPhone 4g using Tapatalk
briannorris
