RSE blank
calif phil
Concordia KS
On my new to me 2012 Tahoe the Rear seat entertainment does not function. No lights on, rear seat heaters or any other functions such as fan speed. Completely blank. I tried pressing the power button numerous times. The DVD player overhead works fine.Also the DVD remote control lights up but does nothing, no sound out of either headphones and they show power when turned on. Fresh batteries in the remote and headphones. Power to all the fuses in both fuse boxes. Any ideas?
Sent from my iPad using Tapatalk
Check to see if it is plugged in. I think you can access the plugs by removing the cup holder insert and look back under there. I saw an '08 like that and it turned out the owner put in a replacement console from another truck and did not plug it in because it was not for that truck.
calif phil
calif phil
Concordia KS
I pulled the module off today and the plugs were nice and tight. I checked and there is power and ground. I am assuming the module is bad.
12GMCYukon
Where was the RSE module located on your Tahoe? How did you determine it was faulty?
D Rollins
