rpm's jump real quick
montec313
anyone know why my rpm's are jumping down then up while going down the road? it has done this in the past but stopped, acts like it starves for fuel for a split second. ill try changing the fuel filter again. just changed it out couple months ago but i put awhole lot of miles on it since then.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Are you shure you don't have a random igntion dropoff as well or your pump is cutting out on you? Maybe wait until it gets really out of hand and throw a fuel pressure tester on it. if it is not happening continously at this point I would not bother with a filter right now. I would give you ignition parts a visual inspection first.
M
montec313
Actually it is jumping up then done. I pay more attention to it. Starting to do it alot.
Smasal
Southwest, Mo
Had same problem last week. Let me guess it has been up and down temperatures where you live the last week or so??? Buy some carb cleaner for $3 and spray it in your throttle body. Take an old tooth brush and clean it out. You will have better throttle response than you have ever felt. Mine was pretty black from all the build up and the condensation freezing and thawing all the time.
SunlitComet
OBS Jedi-Do Good
You sould have seen mine. I am in the middle of the fuel injector upgrade and I have been on the upper manifold with soaps, scrapers, solvent cleaner just to get it clean. I had some serious crust on that damn thing. Still not happy with it but it will have to do.
M
montec313
Ya it has been in the 20's one day n next been in the high 50's. I'm gonna try it
M
montec313
The throttle body was dirty, looked like thick tar. Cleaned that and Maf sensor. So far (100 miles) it hasn't done it.
M
montec313
Well I cleaned the throttle body n stuff n it did do it for couple hundred miles. Now it back and worse than before. I'm bout tired of this tahoe. Tahoes are pos! My friend has one just like it and he always replacing parts. I'm ready to blow it up.
retorq
Kingman AZ
That's the spirit!!
Could be LOTS of things, bad plugs, bad plug wires, dirty this or that, tranny tcc issue, etc, etc.
Are you having any other wierd things happening electrically with the Hoe? The reason I ask is that an alternator going bad can have a similar behavior but normally it also affects other areas at the same time. One time I had an alternator going bad and before I replaced it if I pushed the lock/unlock button on the door the speedo would peg and then go back down. Once replaced issues went away.
retorq
Kingman AZ
That's true ... your computer is expecting a 12v reference signal, it's it's not 12 weird stuff will happen.
SunlitComet
OBS Jedi-Do Good
I would suggest you get access to or see someone with a scanner that can log data and drive at a steady rate. any anomalies will cause a sudden change in data and narrow down the problem. Please don't blow it up. This is something you have to deal with engine systems now that are computer literate.
M
montec313
I just replace plugs wires cap button flushed the trans n converter. The check engine light not even on. Never cuts off. Does have a slight rough idle.
M
montec313
update: i took out the map sensor it was caked with gum. heard u cant really cleaned them but i did anyways. drove it 300 miles since and it drove like a top other than i need new tires on it. lol
M
montec313
lol... it has about 178,000 miles on it. it drive good though. i had got this and it had about 165,000 miles on it. ill seafoam it next oil change.
:waytogo: Keep us posted on if that fixes it permanently!
vsaravia
