Welcome to the Forum from NH.
First, when your engine is at 190-ish, that it the normal operating temperature. When you engine is at normal operating temperature, what is the transmission operating temperature? You should be able to view this, by scrolling through the second button from the top in your DIC cluster of buttons on your front dashboard to the right of your gauges.
Regarding the previous owner's supercharger rebuild project, I am wondering what changes were made during that project that may be impacting you now. I am not very knowledgeable on supercharger projects for these trucks, but other folks on this Forum are, and they will chime in.
Clean, tight electrical connections are very important on these trucks, and any poor electrical connections will raise all kinds of havoc with the truck's electrical systems. I would recommend that you check the battery connections to ensure that they are clean and tight, and I would recommend the same for all ground connections on the engine block and frame within the engine well.
