Reduced engine power....anyone have a stick of dynamite??
I too am plagued with this issue. Why GM went to a computer controlled throttle is beyond me. Maybe a cable actuated throttle fails too often.:rolleyes:
Of course, I did the Dorman TPS. (Mistake) and threw a connector and APPS at it. Still no luck. I recommend buying a Tech 2. Are they expensive for a diagnostic tool? Maybe. Depends on if you are going to be working on your vehicle long term. Eventually, they will pay for themselves in spades. I will be purchasing one when funds permit to tackle this issue.
Current plans to remedy this before Tech 2 purchase are;
New ACdelco TB, clean up engine and body grounds, see if the problem is fixed.
Could the TAC module be bad as well?
That's one of the codes I'm getting, along with the gas pedal sensor.
kevinsbritton
