Rear Passenger Side window problem
Dcchronical1
Ok so i did the led mod with my power window buttons in the rear. driver side rear was perfect and the passenger side rear didn't work. At first i thought i had damaged the switch when I soldered the bulb to it. however after switching the switch out with the 1 from the driver side rear I was able to see that the door wasnt getting any power because i also noticed the door light didnt work either. Additionally I already know that the motor and regulator in the window are good because at this repair shop he used a 12v system to manually roll the window up when i first bought my truck 3 months ago. So with that being said what is my problem and how can I fix this ???
AdrienR
