Rear HVAC
klathan2015
San Jose, Ca
Wht are some possible reasons there isn't any air flow to my rear vents? I can hear the fan in the back cut on but no air from the vents in the headliner.. any ideas?
2013 Chevy Suburban 1500 4WD LTZ
It's probably the mode actuator, there are two back there. The other controls the temperature. The HVAC system is on the passenger side, either towards the back or right behind the 2nd row depending on the system used. Either way, the same panels have to come off.
It would be best to confirm this with a Tech-2 or similar scan tool that can read BCM codes. It could be the controller.
Aftermarket actuators are of lesser quality.
SefWill
Anyone have a definite answer to this issue? Mine blows from the passenger side panel but not the roof vents at all. 2013 Tahoe LTZ.
Trey Hardy
I had to change my rear ac control on the back of the console for awhile it would blow hot instead of cold and then finally quit all together yours sounds like a actuator to me though if you can hear the fan running try a ac recalibration it may get it working again temporarily it’s worth a shot and not hard to do
JeffK
