rear end gearing
Archtoker420
OK guys been a bit since I've been on here. I've been considering getting new rear end gears so I can get a little more get up and go on my 99 yukon. Been thinking 3.73. Or even a whole new rear end with 3.73. Any good brands or opinions on this? Like what would fit and be a good choice. I'm still new to doing all this and don't have anyone to teach me so I'm trying to learn myself
bai78
Surviving
Dallas, TX
Double check your build code but mine stock were 3.42 gears. If you're just gonna do 3.73, then it really isn't worth it.
Personally, I went with AAM gears for my truck after the lift because I was able to get a good deal on OE replacements. The majority of gears out there are of quality. Also, I had a Trutrac to throw in for replacement of that G80 too.
The main thing is having a competent tech do the work thoroughly.
You didn't mention if yours was 4x4 or not. If so, then you need to regear both the front and rear.
Archtoker420
Archtoker420
Mines just 2 wheel. And I'll have to check my build code. I just had a buddy who races his truck tell me getting some 3.73 would help get me going a little quicker.
bai78
Surviving
Dallas, TX
It would help, but also keep in mind that you'd have to reflash the PCM to account for the new gears......shift points, speedometer, etc....Blackbear Performance could do this easily or even someone with tuning software suite. Of course you'd have to pay for the license.
Archtoker420
Archtoker420
I've been thinking about a black bear tune when income tax rolls around. This might be a dumb question but where or how do I find the build codes to figure out my gearing?
SUBURBIAN
All Chevy
Glove box door sticker. The code begins with the letter G. It's listed with all the other 3 digit alphanumeric RPO's on the white sticker. Post all the G codes here.
osiris94ej
Casper Wyoming
4.10 would wake it up but will lose some top end with stock size Tire. But will help a lot with acceleration.
Sent from my SM-N920V using Tapatalk
Archtoker420
Archtoker420
OK cool then I guess I don't need to upgrade to that. So what is G80?
Archtoker420
Archtoker420
Well I don't usually get up to top end much. It's my daily driver and family car. But my first 350. So I'm wanting it to be a beast of a daily driver.
osiris94ej
Casper Wyoming
There is 3.88 for a mild improvement. But for the cost why not make it worth it. Because in the end you will wish you went with more.
Archtoker420
Archtoker420
I was doing a bit of research and found that the G80 is a locking diff. It's limited slip on cars but in the trucks it's a locking. Is that correct? And is that a good thing to have or should I see about getting rid of that for something else? And I was told I would need my computer reflashed if I changed the gearing. Would I have to pay for a full blown tune or is thier an easier way to reflash
SUBURBIAN
All Chevy
Yes, GT4 is 3.73:1. The next lower common ratio is 4.10:1. Not sure why anyone would be concerned about top end in a pickup or SUV. It would be cheaper and easier to find a 4.10 rear and swap it in, instead of regearing yours. The G80 is an automatic locking carrier. Some will call it limited slip, others will call it a posi or positraction or even positive traction. It is an auto locker, made by eaton for much lighter vehicles than any half ton rated pickup or suv. It senses a speed differenoe from axle to axle and locks up. Some last hundreds of thousands of miles, others grenade in dramatic fashion.
Archtoker420
Archtoker420
That's what I read on it. My truck has 184xxx but motor has been rebuilt and tranny or I was told. So I guess mine is in good shape lol. Now let me ask where would I find a 4.10 rear end and is it a straight swap or would I need to replace other parts or modify anything?
Yukon John
SE florida
Unless you are or planning to run 35" tires on your truck you really won't benefit from changing to a 4.10. Save your money.
Archtoker420
Archtoker420
Thanks I'm def. Not planning on tires that big. I'm going more towards a drag style truck than an off road. I want a muscley fast truck if you know what I'm saying. But keeping it daily driver until I can get a new family car or project. So I'm just trying to find ways to make my yukon quicker so I've been exploring trying to learn how and what I can do
vsaravia
