Rear defrost wire fell off....
Tdub
what do you use to fasten/stick it back on?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
Seriously?
You don't.
You pulled the defrost etch off the window itself.
IF you have a big enough soldering gun/ torch, big balls, and lots of pull with the man upstairs, you can try re-soldering the entire pad slightly offset so it touches the remaining defrost inlay.
It only took me 2 hours of near constant work with a torch to finally get it to stay and work.
puckhead
CO
Did you actually break the solder? If so, what Eagle said. more info please, maybe a pic
Tdub
Tdub
Whoa! Yeah it broke right off the window. I'll get a pic of it today and post later. I don't know if someone bumped it or if it fell off when shutting the hatch.
weo1209
Raleigh, NC
Is there some kind of adhesive that you can put on to make it stick, but still maintain the conductivity?
04Hoe
Go to the local Auto Glass Shop, they will re solder it for around $30.00.
johnsonwillie199
