Rear climate only blowing cold air
JestersHK
Having a weird issue with the rear climate control in our 21 YukonXL. Started noticing when remote starting the vehicle when cold out that the rear would be blowing cold air.
If i started normally it would be fine and blow warm air.
Now the past few days it's been in the teens here and the rear heat is not working at all it just blows cold air whether remote starting or not.
Craziest thing about all this is our 2022 Acadia is doing the same darn thing. No hot air on rear climate control. Acadia is still under warranty, but we just went over mileage 65k on our yukon... how convenient.
Any thing I can check? Hopefully something i can get to easily for repairs. No CEL but going to have my buddy check for codes with his scanner.
JestersHK
JestersHK
Just to update here, threw yukon on the scanner and not a single code... started with basics and found the coolant was a little low and there seemed to be a bubble in the rear heat line. Front lines were hot, rear lines were cold. Dumped some coolant in and held some rpms while buddy pumped and bled the line. Corrected the rear heat issue, but now gotta figure out where the coolant went. Have almost 70k on this one without any issues.
SavageDad
Having the same issue with the rear heat blowing cold, checked my reservoir and found I was nearly a gallon low so I topped it off and it's still blowing cold. I'll be on the road for a few hours so I'm hoping it works its way through, but if not I guess I'll be pulling the rear lines.
SavageDad
Update a quick WOT romp down the freeway and we're toasty all around.
BadDaddy2003
