push to start
blue99tahoe24
bout that tahoe life
joliet il
hey can anyone tell me how to install and wire a push to start button and if you guy already did can i see some pics i like how the new cars have them thanks
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Never seen a turn key kit but you could build one with about 10 or more relays but it does not have safety inhibits so you will have to make some. A PLC(Programmable Logic Control) setup would be ideal. Still going do one myself but have not gotten around to drawing out the circuits yet.
blue99tahoe24
blue99tahoe24
joliet il
i still wanna be able to use the key cuz i seen some on youtube that they put the key in turned it to the on position and then pressed the button to start it
SunlitComet
OBS Jedi-Do Good
Actually just found two after using a different serch term than before.
This on uses rfid which is totally sweet.
http://www.digitalguarddawg.com/KEYLESS-IGNITION-AUTO--PBS--PG-1temp.htm
This one use original key or key fobs:
http://www.gallotech.com/
I want the rfid myself but would have to make a couple of changes for safety inhibits.
As if 80+ new wire connections in my dash already aren't enough right now. My only options at this point is to make a wire harness extension and mount the controllers in the right front corner above blower motor. But I always love more wiring mods so the rfid is what I am going to go with.
SunlitComet
OBS Jedi-Do Good
The one that uses rfid transponder even has a variety of buttons including a Lexus one. Also so one that say either off, accy or on.
JeffK
