Ported GEN4/TBSS intake manifold & ported LS7 TB
1BADI5
DMV
I have since moved up to the FAST LSX r/t 102 intake manifold and Snake Eater Performance 102mm TB.
Picked up 20 wheel on the dyno. Both the intake and TB were brand new units when ported and installed. Only ran them for about 2500 miles when removed. I ran both before my dyno tune and ran great, no CELs.
Intake had the TB opening opened up and the runners were port/gasket matched. Went from 1" to 1 1/8" I will post pictures later.
Simple remove and replace parts for your truck, can be done in about and hour with no downtime for your DD.
Looking for 500 shipped in the lower 48.
1BADI5
1BADI5
DMV
Sure let me post them up.....forgot to do it the other day
Stock vs ported throttle body opening
IMG_20200726_180455.jpg IMG_20200726_180500.jpg MVIMG_20200726_180445.jpg IMG_20200726_180441.jpg
1BADI5
1BADI5
DMV
And now in intake runners
Again some more stock vs ported.
Opened up the runners via a gasket/port match to the cylinder heads. Went from 1" up to 1 1/8"
1BADI5
1BADI5
DMV
I do not have a stock LS7 TB on hand for comparison, but here are the pictures.
Everything was hand ported by me paying close attention to material thickness to ensure the strength of the item was not compromised. Again all items were tested and performed flawlessly.
IMG_20200815_104115.jpg IMG_20200815_104101.jpg IMG_20200815_104105.jpg IMG_20200815_104127.jpg IMG_20200815_104152.jpg
Man! That's some nice n' smooth porting work. What did you use to port? Just a dremel for plastic?
Sanchize6
