passenger side mirror
Phil S.
Wheaton Illinois
I was replacing both mirrors and after getting the drivers side done, I opened up the trim on the passsenger side. The wire for the mirror is pulled pretty taunt in the downward direction. I cannot access the plug because of this. I think I will wait until it is warmer outside to take the door panel off. My question is with the interior door panel off will I be able to access the wires and find where they are snagged?
I also plan on doing the interior LED swap at the time. Any suggestions on how to remove door panel. I don't want to break all the Christmas tree clips
99Yuk
Northern Ontario, Canada
I recently upgraded my mirrors and I also found my passenger side plug was very low in the door and hard to get to. I thought that problem was specific to my truck. Now I wonder if it's a common thing.
I took my time, and pulled on the mirror wires enough to where I could see the plug and wrap a stiff wire around the plug to prevent it from falling back down. You can see how I changed my mirrors HERE.
If you do end up needing to take the door panels off, you can see how I did mine a while ago HERE.
I don't know with 100% certainty if you could get to the wiring without the door panel on, but I would imagine that you could.
Good Luck with yours!
EDIT: Odds are that your gonna break some of those clips and some may already be broken. Just buy 20 new ones (10 per side).
Phil S.
Phil S.
Wheaton Illinois
your heated mirror replacement was my guide and I thank you for it. The only change I did to the procedure was after I dropped a nut into the door GRRRRRR!. I then stuffed newspaper into the space below the work area in the door so that when I dropped a second one I could retrieve it easily. I also used a small amount of scotch tape to hold the nut to the socket when I was re installing them so it made it easier to hold them in place.
I pulled all the newspaper out when I was done and the tape broke off as I tightened the nuts down so there was no issue there either.
I will do the passenger mirror soon I just don't want to monkey with it in the cold weather. I am only replacing it so it matches the drivers side exactly. I plan on doing the interior LED upgrade soon so I will probably do it then while trying to replace the lights on the door switches.
99Yuk
Cool! I'm glad that you found the guide usefull.
I know what you mean about dropping the nut. I was so worried about it. I didn't think of putting something in place to catch a nut if it dropped. Good Idea.
At first I was thinking of leaving the nut in the door if it dropped, and use another nut for the mirror, but I wondered if the dropped one would rattle in the door and drive me nuts. So I figured that if I dropped one, I would have to take the door panel off to retrieve it. Didn't want to do that, so I took my time. When my hands would get cramped playing with that back nut, I would take a break, etc.
I hear ya about the cold. I have small hands and did mine in the summer, and I still cussed alot and it took forever.
twopoint
Kitsap County WA
Well he's right about the small hands, I too followed the guide to replace my non-heated mirror.
But my hands are not so small, I had a hell of a time with the nuts, ended up
dropping one.
so far, no rattle yet
and yes the plug was really tight
Luggz
