Park assist
George Owens
is there a way to possible re calibrate or set the park assist it seems to only beep once than after that it won't let me know if I'm close to something
PG01
Up here to the right
May have to dealer flash it. Did you turn it off and leave it off for a few minutes and drive around. Shut truck off then start it up and try it out.
M3kanic
Mine was acting funny after I pulled my camper for a few days. I ended up turning the key to the on position, putting it in reverse and tapping (messing) with each sensor and it started to work again. I had read somewhere that if you do that you can hear / feel them vibrate. I did not hear or feel anything.
PG01
Mine goes off when i pull any trailers or say park assit blocked and then goes off... never felt it to see if it vibrates..ill have to check it out..
ZaZaZazzels
