P0420 Code, has anybody found it to NOT be a bad cat?
mftrnr
Pretty much like the title says, it's the one code I was hoping would clear when I got rid of the rich fuel condition. After resetting the fuel composition (previously had P0172/P0175) this was the only code that came back, anybody found a solution other then cats? I'm still pretending there is hope it's something else (cheaper).
Or does anybody have any suggestions for what readings to check with a scanner? Any way to confirm it is a bad cat?
Code P0420 stands for “Catalyst System Efficiency Below Threshold (Bank 1).”
Thanks!
BG1988
i would check the o2 sensor might be slow or damaged
if the cat est temp is going up then it works, it should be 350c-700c depending on the load... also check and make sure other sensors are working correctly
if the O2 sensor is at zero then it's dead (sometimes may report 0.00 on DFCO)
(the rear sensor for the most part should be stable )
if they're following then the cat is dead
wsteele
Cats are expensive and pretty durable. I would watch this YouTube video all the way through and maybe check everything he recommends. Most of the specialty tools he uses are available for loan/free rental at stores like Napa.
Good luck.
Thanks!
Nope, been there, done that.
If one goes, the other isn't far behind. Replaced mine with Magnaflow cats and y-pipe from a vendor on here, GotExhaust. At the time it was less than half the price of OE and the piping is much better for flow.
wsteele
Were they CARB or just Federal compliant?
Do you happen to remember what the two cats, Y pipe, etc. cost you?
I know it is just a matter of time for me, so lining my ducks up.
BG1988
i had both p0420 and p0430 (triggered by P0069 code) codes before did not need to replace them that is why it's a good idea to check other things first... a stuck open tstat for example could cause it
unless he had a misfire this is why you check the o2 sensor data to see if it's following.. if it's heating up normally and not following the cat is ok... it's something else
when I had an actual failed cat it check engine instantly when behind a diesel truck....it also followed
KEEP the old Converters they're worth BIG $$$$$ right now
BG1988
KEEP the old Converters they're worth BIG $$$$$ right now rather then return core
they forget to change the price here..
$915 at that price it's cheaper then the after market after market one will be 1900$
i'd call them up see if it's in stock and the correct one for your SUV vin verification 972-864-9725, be ready as they answer instantly
this is for the OP
all of them are 50 state... as they changed the rule in 2008 for federal
Federal, I forgot that my truck is labled California emissions! No other differences though.
Yes, in early 2018 I paid $585 for Magnaflow #51578
BG1988
the same one is way more money now almost 2x the cost might as go with the OEM though
mommy2boys211
