Outside air temp
Jorgez28
I have a 2015 Escalade that says the out temp is 30 degrees. Needless to say I live in the desert and that’s wrong. It there way to reset the sensor.
you can just disconnect the battery and touch the cables together then re-attach. If everything else is working properly and the sensor still does not read correct after driving 5 miles @50 mph then it may need to be replaced. easy to do.
Jorgez28
Jorgez28
That is possible do you happen to know how to change the units.
markni12301
Should be similar. There are many other threads like this and YouTube videos. May not match precisely your year and model but it should be similar if not exactly the same.
Durobans
