Out comes the 5.3 In the 6.0 **
Nickleahy23
Portage/Menomonie, WI
good luck man..the bellhousing bolts are a ***** on the tahoes cuz the motor sits a little further under the firewall but other then that its a straight foward swap...im glad i swapped mine..now i just need a new trans since this one started to slip..6000lb suv+155k miles+6.0= slippage
ecordell
CordellDesigns.com
Merica
good luck man..the bellhousing bolts are a ***** on the tahoes cuz the motor sits a little further under the firewall but other then that its a straight foward swap...im glad i swapped mine..now i just need a new trans since this one started to slip..6000lb suv+155k miles+6.0= BREAKAGE
There fixed.........:Handshake:
bkboatnsleds
bkboatnsleds
McHenry, IL
Thanks guys!!
Its IN!!! - have not driven it yet - needs to be tuned (today)
Only snag we hit was the headers I bought. I ordered them for a 6.0L - which did not work b/c of the difference in the exhaust flanges. So as not to delay I just put the stock 5.3 headers on and will replace them when the Gibson 5.3 headers come in.
Otherwise it was not to bad - a lot of work but mostly straight forward.
Few of the 6.0 going in
More pics to come!
blueflamed03
Oklahoma
The PCM will work from the 5.3 to the 6.0, just best to get tuend for the 6.0 to maximize performance.
viximaging
Houston/Spring
Thanks guys!!
More pics to come!
Did you just flat black the whole engine or is it dirty?
Mr45
Florida
How many hours do you think the actual swap took?
048tahoe
