Oil sender screen
corvettetim
Hey group, my oil pressure gauge was working normal then I noticed that it pegged all the way to 80 psi. The next day I started it and it went to zero so I am assuming the sender needs to be changed out. Will be doing this Monday afternoon. What I was wondering is do you leave that screen out when you change the sender or does it matter. 2007 Yukon Denali with the 6.2 and 215,000 on the clock. Thanks.
C
corvettetim
If it has one leave it out upon reassembly, you don’t have AFM so there shouldn’t be one in there…
Ok thank you very much for the response. I wasn't sure so that is why I asked. Going to try and do it without removing the manifold. My C6 corvette was a pain to do but I did it without too much trouble. Thanks again.
justinakay79
