I’m starting this thread because i have a pretty specific oil-pressure / rpm / longevity question that has been bouncing around in my head lately.
I recently moved to a town up in the Rocky Mountains, so going over mountain passes is something I’m doing more often than most people. I usually try to stay at or below 3500 RPM when I’m climbing the 6-8% grades because I’ve noticed that my oil pressure goes from about ~45psi to ~65psi or more pretty quickly when I rev above 3500 RPM during a climb. Is that rise in oil pressure normal? Would running at a higher RPM and oil pressure (say 4k @ 70psi) for a minute or two here and there have any adverse effects?
Related to that - what is considered a safe RPM range when doing longer sustained climbs? I’m not trying to break the speed barrier up hills, I just want to understand how hard I can push the burb and still keep it happy. Every now and then people slow down to pass a slow semi up a hill, and it kills momentum, so the 40-60mph acceleration can feel…spirited.
FWIW Usual pass altitudes range from 8k ft to 11k ft above sea level with speed limits in the 55-65mph range.
