Oil Cooler Block Off Gasket
Plimbob
Des Moines Iowa
I am diagnosing an oil leak on my 2007 5.3 (309K) and after reading some of the posts I am leaning toward the oil cooler block off, lots of oil around the filter. I am pretty sure is not the filter.
However, other than taking off the plate, is there a way to know beforehand if its the wide oval gasket or the two hole gasket?
Thanks for any feedback!
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Do yourself a favor and get the billet plate and gasket/seal kit and be done with it. The OE plate warps and hardly ever reseals correctly.
St. Louis
The 2 hole type of gasket is used if you have the 2 lines coming out and going to an oil cooler.
If you have no cooler then it's the oval gasket.
OR VietVet
Willamette Valley
Yea, in the one I referenced, it shows a round o-ring but you just shove that o-ring in to the oval shaped slot on the back and tighten down and good to go. The billet plate does not warp.
St. Louis
BTW, is this vehicle 2wd or 4wd?
If 4wd you will probably have to remove the front driveshaft U joint straps to be able to drom the shaft down a bit out of the way so you can get your hands up there.
If 2wd nevermind the above info, lol
Fless
Moderator
People's Republic of Colorado
Here are a few pics of my '04 4x4 with the front propshaft out of the way (I changed my when I did an oil change, so the filter was off). Thread link goes directly to the post with the pics.
St. Louis
What sensor is that right above the block off plate?
JPeter
