OEM Navigation fit?
madodger88
Seattle
Will an 07+ Esky OEM Navigation fit my 08 Tahoe? I know I have to get an amplifier keep the radio working (I currently have single CD unit) but will the head unit fit/work?
Sorry if this has been covered, did a search but couldnt find anything and I found a unit for cheap.
zach2011
Platinum Member
No, you would have to change the entire dash to get it to fit and I don't think the wiring is the same. Not even the speakers out of an Escalade would fit a Tahoe, the harnesses are different sizes.
When I drive my mom's 07 ESV, the nav screen is noticeably a LOT bigger. The placement of the AC and controls and all that are way different. The only way you could get it to fit is, like I said, you change out the entire dash. Meaning you'd have to also change the computers and program the BCM to think it's an Escalade, just to unlock the nav's Theftlock for use, and you would need to install the Escalade gauge cluster, which is NOT an easy job as it is not plug-and-play in Tahoes/Yukons.
You could buy it (if you can get it really cheap) and then resell it and make some money? Then you can buy the Tahoe nav if you don't have it. Haha, just a thought. :)
Eickybobby5050
