O2 sensor question
Big Poppa Pump
Brunswick Maryland
I was wondering if the 5.7 in my '99 would benefit from prophylactically changing the O2 sensors on the truck. I am not showing a code but my truck has 172k on the original sensors. I heard that that sensors from that era are good for about 80k.
2000tahoeZ71
Four but two different parts. . The front two are the same, and the back two are the same.
Big Poppa Pump
Big Poppa Pump
Brunswick Maryland
Sweet thanks. I'll check Rock Auto for prices. How do I tell if I have a 4L60-E or 4L80-E transmission code?
2000tahoeZ71
If you have amazon prime, they are usually the way to go. Make sure you get AC Delco part. rock auto usually is a little cheaper than amazon, but will get you with shipping.
ezdaar
Chat Troll
Redneck central, Aka Houston
4L80E is shaped like a rectangle with two corners lopped off and 17 bolts.
700r4/4L60/4L60E is pretty much square with a couple irregularities and 16 bolts.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
reading the wave form activity helps determine when you need to be change individual ones as opposed to all.
GMT800 2005 Tahoe Z71
Navy Supporting Member
If you do go to Rock Auto and then try to save money by the least expensive sensors they could require you to splice the old connector on to the new wire so look at the pic of what you get but a true AC Delco part will have the connector.
Big Poppa Pump
Big Poppa Pump
Brunswick Maryland
Been there and done that and have learned my lesson. Thanks.
varminpoolteam
