Nv3500
yukonrrican
Tha NV3500 from an S10 is the same NV3500 from a K1500? Same torque capacity?
Can I install a Yukon electric transfer NP243 to this NV3500 or need to use the NP231 transfer?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
cross member placement may need to be changed on the c/k, maybe drive shaft shortened a bit. i think. with the correct adapter the 243 should mate to the nv3500. no idea why a 231 would need to replace it. that is a weaker case i thought. nv4500 is more ideal tho. much stronger.
Y
yukonrrican
Which transfer is stronger??
NP231 or NP243?
Do they has the same input pattern and splines?
chaingun427
OBS Mad Scientist
Mooreland, OK
they are a 32 spline output, and the input on the tcase should be the same as a 241 or 246 mated to a manual or a 4l80e if that helps you find one.
JPeter
