Not a Tahoe, but I need help with my '92 K1500 (TBI) please guys...
ChrisAU
ChrisAU
Birmingham, AL
Sooo I got the TB rebuild done, unplugged the battery while I put it on to reset the ECM, plugged the battery back in after I was done and did a IAC relearn before cranking it. Immediately obvious that the passenger side injector was leaking, so I cut it off and redid all the o-rings in the pod. Cranked it back up, no leaks. But it runs like ****. It stalled the first time I put it in drive. However, after re-cranking it it did start to run better and it didn't stall the next time I put it in drive. Its been suggested that I run it 30 miles or so after a re-learn for it to get perfect, so we'll see. I needed beers while doing this and since my rear bumper is removed I don't have a license plate, so I'm not driving it tonight.
TB Before:
TB After:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If you remove it it is supposed to be relearned I believe my manuals show. Besides after crappy running an a clean rebuild why would you not do it. Would you like the exact procedure Atomic?
ChrisAU
ChrisAU
Birmingham, AL
Battery unhooked for a bit to clear computer, hooked battery back up. Jumped top right two terminals on OBD1 port, turned key forward, waited 30 seconds or so, turned key off, removed jumper, cranked truck.
Two things in that procedure can tell you you did it right: 1) the SES light flashing once, pausing, then twice for a code 12, which is normal operation, and 2) you can feel the valve body of the IAC pulsing as the motor repeatedly draws back.
AtomicHoe094
Atomichoe094
cleveland, OH
Gotcha, the IAC will reset/learn it self within 100 miles of driving as well. If its not doing any better by that point, you have a different problem.
Did you clean all the ports in the side of the TB well? the egr one gets pretty dirty and clogs the passage way..
ChrisAU
ChrisAU
Birmingham, AL
Oh yeah I blasted and q-tipped the hell out of all ports, LOTS of **** came out.
Buttt, it seems to be running better, but the same problem exists...although I was unable to get it to stall. It did run perfectly smoothly going down the road and I can feel a power increase, but at idle once warmed up it still has the same problem. When I got back from a test drive today I left it in gear for a bit and videoed the tachometer and then cycled through gears. You can see what I'm talking about, every time you see the needle move the truck shakes. I'm really not sure where to go from here.
(CLICK IMAGE TO PLAY VIDEO)
retorq
Kingman AZ
That shows you are idling at 200 RPMS ... you got something else wrong.
ChrisAU
ChrisAU
Birmingham, AL
I have my old IAC and ICM, gonna try them one at a time to see if I can see a difference. If both of those prove to be good, then I'll try a new CTS. That will complete the testing of sensors on my truck that aren't brand new Delphi products. After that I'll look at wiring in a new harness for the IAC and MAP. Both have broken tabs but seem to be seated just fine.
ChrisAU
ChrisAU
Birmingham, AL
Well this sucks guys. I replaced the CTS pigtail since I had one, no difference. I then threw in the old OEM ICM and it runs worse. Complete ass on cold start, likes to stall. I just ordered a Delphi ICM, Cap, and Rotor, so cross your fingers...
I'm so pissed off at it. I'm going to take it to the shop next week and tell them to have fun and not to call me until it runs right if I don't get it fixed by next Thursday.
Gzes
the drifting 2dr
Wichita tx
Yep when I get to that point where crap won't work I just call the mechanic.... We have a little pickup that doesn't want to work.... It use to run perfect but now doesn't.. changed a lot of crap and still no good. Good luck with ur rig
ChrisAU
ChrisAU
Birmingham, AL
Just an update...I've thrown the white flag, taking it to a shop this afternoon and telling them to have fun. Hopefully its something small, but I just want it fixed. Please pray for me and my wallet lol
ChrisAU
ChrisAU
Birmingham, AL
I feel for ya. I've been fighting mine since last November. Here is a prayer somebody posted for me some time back...perhaps you can get a smile out of it.
Oh dear sweet eight pound, twelve ounce baby Jesus, have pity upon our poor brethren, who being righteous in Your eyes is attempting to return Your Heavenly Creation to its rightful place among the OBS faithful. Shower him with blessings of wealth, prosperity, and PB Blaster for those especially stubborn nuts. Bring new life to his faded door panels, and set him on High with fresh rubber and a suspension lift, if it be Thy Will. Let him be delivered from the heathen ways of the Cult of NBS, and array before him an army beyond measure to protect him from his wife or girlfriend, should the Enemy have lured him into congress with such a creature. Forgive him his debts as he hopes his credit card company will, and carry him forth in glory undimmed until the breaking of the world. In Thy precious infant son's name, AMEN!!!!
bowtiefreak
No Quarter
Near Philly
This is priceless.
JamesinAbilene
