No Transmission Service or Tune up
Ruikee
2015 LT 4WD
I bought this vehicle in 2017, ex rental, had about 60k miles if i recall. I am coming up on 200k miles. Since i have had it, i have done nothing but change the engine oil, tires, and brakes. Just did shocks and struts about 10k miles ago. I havent had any issues, gas mileage is still pretty normal.
Occasionally the tranny upshifts for a second then back. Checked the fluid, still good, doesnt smell burnt or anything. Took it to a trans shop. He asked if i have serviced it ever, and I said not since ive owned it. He said not to touch it or problems will start up due to the detergents in the new fluids, almost certain it would cause problems.
Thoughts?
And as far as a tune up? Should i do anything about that, and what should be replaced?
Again, no issues TBH
2015 LT 4WD
Thoughts?
These aren't Turbo 350s, change the fluid. Just change out half with the filter. You've been fortunate, the transmission thermostat causes them to fail in about the half the time. If interested in lowering its temperature, look up "flip the pill" here and other forums, easy peasy. GM also makes a lower temperature thermostat now as well.
Tune up consists of plugs and wires. Time for an air filter?
Bill 1960
Testing the Limits
Replace the plugs and plug wires. These will run with incredibly bad plug gaps, but you won’t notice any degradation in economy or performance because it’s so gradual, until it reaches total failure- then you get a miss.
I would change the trans fluid. I wouldn’t flush it, or put any foreign chemicals or snake oils in it. Just drop the pan and replace the filter and the amount of fluid lost. I think your risk of continued neglect is higher than the risk of new detergents breaking something loose.
Opinions do vary on this. I can easily see why a mechanic or professional shop doesn’t want to touch it; if it fails they’ll be blamed. OTOH if it fails as-is it’s the owner’s fault and they get to sell a new transmission.
R
Ruikee
Thanks, i did forget after posting that, yes i have changed the air filter a few times. I might add, i also tow my boat a lot and sometimes long distances. Any recommendations on plugs and wires? I also did change the internal cab filter once as well.
R
Ruikee
Thanks, any recommendations on plugs and wires? any recommendations on what type fluid to use at this point? I also tow my boat, sometimes long distances as well.
That does make sense about the pro shop not wanting to touch it...
Miami-Dade
Moderator Supporting Member
2015 LT 4WD
Thoughts?
When it comes to changing out the the tranny fluid I only let the dealer do it. Not a trans shop. The dealer would also have to have a 5 star review or close to it with mostly positive reviews.
I stopped doing tune ups years ago. I do change out filters when needed.
My 2016 goes in for regular service every 5K miles.
But that is just me. To each their own.
OE plugs and wires for me. Get your VIN out and plug it in here:
Run the severe service schedule from now on, not double the "I don't drive it anywhere" schedule! LOL
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
What has been said already. IMO, do the Genuine GM plugs and wires, clean the MAF and MAP with correct fluid from parts store, change the trans fluid in the pan and the filter and maybe do again after 15k miles to try and get some more fresh fluid in there and I would not worry about the detergents recommendation from that shop. How do the belts look? How do the hoses look? Time to flush coolant and brake fluid and change fluid in diff's and transfer case and power steering fluid.
Or drive it till it drops or leaves you stranded because it likely will one of these days. "Maintenance pays and breakdowns cost".
on the flip side of that coin it's probably going to be cheaper to fix the transmission now rather than later
I would just have them go thru it and replace what is worn, do the common fixes and upgrade the torque converter as that is the weak spot and you are well into the mileage where it happens, it's going to suck when you have to have it towed and have the boat find a way home as well.
drakon543
im going to side with the trans shop that said not to touch the trans. regardless to the type of automatic transmission its still operated by servos and pistons and whatever else that need to be sealed properly for proper operation. if the fluid isnt changed regularly the natural buildup of an automatic transmission starts and becomes whats actually sealing the transmission actuators and such. the fresh fluid will clean that out of where its been sitting due to the fresh detergents and the sudden change in fluid pressure from fresh fluid. changing the fluid on a transmission like yours that is still working but is long past its service date is going to give you at best a 50/50 of making it better or killing it
R
Ruikee
MAFand MAP?
robhotdog
2015 LT 4WD
Thoughts?
Check your OWNERS MANUAL 100k everything pretty much needs changed! Plugs tranny rear diff transfer case and front diff if 4x4..engine coolant..ck hoses and belts! You're lucky it's taken this neglect. Tranny change is up to you. If it's doing something funny a service Wont fix it. Likely trans rebuild in your future
R
Ruikee
So i took a visit to the dealer today and the dealer service center told me not to touch it either! Kind of shocked. I also seen a youtube video where a guy replaced the fluid by pumping it out of the dip stick with a pump. Of course the filter was not changed, but great idea vice dropping the pan. got some decisions to make....:confused: ill keep ya all posted, thanks for all the info and suggestions!! Greatly appreciated.
steve45
At the risk of jinxing myself, I don't change transmission fluid. I've had my share of transmission failures over the years--NONE related to fluid. All were mechanical failures. A couple were components that broke while still under warranty.
I would definitely change the heater hoses. I just replaced the plugs & wires on my '09 Tahoe at 200K as it was idling a little rough sometimes. As preventive maintenance, I'm going to replace the fuel pump this week, and I replaced the alternator last month.
lbenson
I wouldn't touch the fluid if its got 200k without any previous service. Did my regular 45k interval flush on my 2015 with the 6.2L and 8 Speed and the flush finished the job of killing the transmission at 175k. Wasn't running great by then but it only sped up the death of it. I've heard the 2015's with 6 speeds do pretty well... 200k+. (2016s+ are a different story). But would do better with regular service. I would be surprised if you can get it to 250k, but if you do that's a good life for a transmission in these trucks.
R
Ruikee
Thanks, so when you say died, what actually happened? totally stopped pulling?
lbenson
Died meaning in need of total transmission replacement. Thing still moved but not that great. It had delayed engagement (Slammed into R from P), N was another R gear, slipped from 1 to 2, underpowered on highway, internal computer wasn't responding to anything, and a few other things. The thing never once threw a check engine code though. Got rid of the truck that day and now drive my mother's 18' Yukon Denali that only had 60k miles on it at the time. Was quoted about $4700 for a new transmission, which wasn't horrible (have a relationship with dealer though). Now I would imagine it would be more due to inflation and shortages. Glad I got ride of it though. Have started to hear stories about the 6.2L blowing up at mileage before my 15' had when the tranny died (from guys that only drive highway miles and baby it). Not sure how the 5.3L has held up, but maybe better than the 6.2L.
I would be worried about your 6 speed though. 200k no service is a good life, especially if it is just having issues.
CrackerJack135
