no brake lights
kjacob1115
I have a problem with not having brake lights unless I use my trailer brake control box. I replaced the brake switch on the pedal and nothing has changed.
K
kjacob1115
Yes all other lights work. Were is the multiassenbly switch?
---------- Post added at 06:24 PM ---------- Previous post was at 06:20 PM ----------
I take that back they did work now I have nothing at all
SunlitComet
OBS Jedi-Do Good
unknown at this time.
multiswitch is your big stalk on the left. turn signal, hazards,cruise control and wiper combo unit. try to get a delco replacement. amazon or dealer. about$130. in the meantime cycle you hazard switch a bit you might get some of the light back temporarily.
ls2hoe
bay area ca
so i just changed my turn indicator lever and now i don't have brake lights. My trucks getting the hydroboost conversion right now so when it gets back ill have to check it out. is there a wrong way to install the lever to where the brake lights won't work? Im having the switch changed with the conversion. thanks again
CKendrick
