NO Air Out Of Front Floor Vents REAR HVAC Not Working Properly Related?
jmm121783
Searching for the next sunset...
Detroit
Hello guys,
So my heat blows hot (doesn't warm up as quick as my turbo4 lol) but it blows hot it just isn't coming out of the vents I am directing it to come out, which would lead me to believe I have a vacuum leak. The weird thing is I can't find one and when I switch the buttons flaps are moving but it just seems to TRICKLE out the DRIVERS SIDE FLOOR vents and with temps in the 20s this morning my legs were freezing all the way home.
Now in the back, the HVAC is getting hot coolant/AC to the unit, confirmed by touch the housing and feeling warmth/cold. There are two actuators on the back unit that controls HOT vs COLD and CEILING vs FLOOR. Do these actuators go bad? Is my front issue affecting the actuators in the back?
Any ideas? Im going to check to make sure all "ducting" is hooked up correctly because on the drivers side it does feel like the manifold or duct is super loose, is that standard?
Anyway going outside to put the interior back together as much as possible after tearing it all apart to "decommission/re-commission it for myself lol time to get this Leather Steering Wheel on
One or more of your actuators is out of sync and or going bad. A Tech2 will tell you instantly which ones and why. You can also do a relearn without the Tech2 and see if that clears things up but will still need a way to clear codes first. If not, you'll have to replace the offending actuator. Is yours manual or automatic?
B0228 is for the recirculate actuator.
B0413 is for the drivers air temperature actuator.
B0423 is for the passenger air temperature actuator.
B0433 is for the auxiliary air temperature actuator.
B3779 is for the mode actuator.
B3782 is for the auxiliary mode actuator.
jmm121783
jmm121783
Detroit
Wow I dont know how my response never uploaded to this thread, mustve been a issue on my cell phone.....anyway my response was:
No CELs on at all, unless my CEL light is bad. How do I relearn the actuators? Any posts, links or videos would be great. Also is this a common issue? My climate control is manual, aka I set the temps and the fan speeds. I will mention that the front blower needs to be turned up to the highest 2-3 positions to get any REAL volume out of any of the vents, could I have a slowly dying blower motor in the front or a clogged cabin filter?
Thanks for the help hoping to get this solved soon!
No check engine light, the codes are internal when the issue is not drivetrain related. These trucks do not come with a cabin filter unless you back fit one in. The blower motor could be going bad or could be straining to do its job because of an actuator. Youtube has videos but you must clear the codes first.
jmm121783
jmm121783
Detroit
So even if there are no CELs a Tech2 or similar device has to be plugged in to "reset" the ECM or would this be the BCM?
Going to check YouTube now
Your CEL (Check Engine Light) is not going to light up because of an A/C or other non-drivetrain related problem.
If you want to do a relearn of your A/C systems actuators, you have to clear the codes for those actuators first.
jmm121783
jmm121783
Detroit
Again so bottom line is I need someone with a device to clear that sort of code correct? I can't "goto autozone" and get this figured out?
My front blower motor has to be fine because when I blast it out the top vents it works great. Its just super weird that when I have it on floor only it still comes out the windshield vent and barely comes out the floor AT ALL.
Well, I don't think Autozone would have such a tool but it cannot hurt to ask.
Let me renew the call for a map, showing the cities where the folks on here live (if they choose to participate). This is so we can get in touch with folks nearby for help or to help or whatever.
A Tech2 could've given you an answer a week ago, either fixed it in minutes or told you exactly what needs doing.
jmm121783
jmm121783
Detroit
I agree SWATHDIVER, a map would be a great feature so that we could hang out and get together with people willing to participate in such shenanigans lol. I should just post something on craigslist asking for someone with a tech2 and will pay them 20$ to scan and help out for an half hour or hour!
BACK TO THE HVAC, I will also update the first thread so that all the info is in the first post. I got to inspect a little more and I am getting ZERO air at all out of the feet no matter what the setting, feet or anything. When I do have it on the feet ALL OF THE AIR comes out of the WINDSHIELD vent....is there a way to sync this actuators? Could this be why my REAR HVAC is all goofy?
jmm121783
jmm121783
Detroit
well idk who did it but I just realized the Check Engine Light, Cruise Control Light, Low Gas Light, and god knows what other lights aren't working on my truck. Idk if they were uninstalled by Asia Motors the place I bought my truck from or if the govt had them taken out but this is pretty wild to me, seems almost illegal to be able to sell a car without a working light.
Anyway Im gonna have to pull the cluster and see whats up, if the bulbs are missing, bad or blown or possibly disconnected. This sucks
jmm121783
jmm121783
Detroit
gonna take out the speedo today hopefully and see whats up with the lights
HAPPY THANKS GIVING EVERYONE!!!
jmm121783
jmm121783
Detroit
has anyone bought one of these supposed Tech2s off of ebay for $350?? That seems way too good to be true.
MidwestMike
Southwest Michigan
You can do a reset of the actuators for testing. You can do a search, but I believe it was as simple as taking the battery cable off and turning the ignition key.
There are also more detailed versions, that may not fit or be needed.
https://sparkys-answers.com/2011/08/hvac-actuator-recalibration-procedure.html
I would start with just the battery and key and see if it works for you for one cycle, then a little search will tell you which actuator.
The heat/cold one is easy enough under the passenger dash, there is another one center/driver side that is also accessible. Another one is a whole dash project (some other vehicles require the windshield to be removed..)
Skiroy56
