new to this
yukon007
Hello im new to the forum and lifted truck thing. I have a 2001 yukon xl i want to put 35/ 12.5 / 22's on and was wondering what lift should i get. i live in va so they trip on about how high you go so i dont want to go up to much and i dont mind a lil trim trim . wont do any off roading more so just for looks.
TheAutumnWind
Those tires, something weird.
Cant quite figure it out...
:hmmm2:
LOL! Welcome to TYF. :cheers:
Deepdish. Stance:nation
---------- Post added at 04:10 PM ---------- Previous post was at 04:10 PM ----------
What is the max height you are allowed?
M3kanic
Minimum for 35's is 6 inch.
Sent from my SM-G900V using Tapatalk
00'BlueSteel
Carolina
Yeah 35x12.5 is not the kind of thing you can make work with a budget lift
Like they are saying it will hard to do less than 6" lift and fit that setup.
And if you are wanting those 22s to be 12 or 14 wide you will need atleast 6" lift and trim.
I have lift keys cranked with Cognito UCAs and did the Norcal Fender mod (google it) and removed the lower front valance, and still barely fit 33s on 20x12s. If I punch it in reverse at full lock it rubs. My wheels are high offest -44. If you go lower offset it helps with clearance but then you don't get that awesome deep dish. I will grab some fender clearance pics at lunch.
But here is UCAs, keys and 33s on 20x12s -44 offset.
just image how stuffed 35s on this would be
00'BlueSteel
Carolina
These are with the wheel turned so the tire would be as close as it can get.
This is with the norcal mod, and the fender behind the liner cut and beat back as far as it goes and with the parking brake cable relocated.
00'BlueSteel
Carolina
New hand model @ TYF
Go rub some grease on those thing, ya hippie.. :jester:
lol I'm a web developer by day, they don't see much grease before 5 on week days
. really I just wanted to show off the goods :hands: I'm no merman but hand game on point :licklips:
liftedtahoe
arkansas
Here is my tahoe, it has 3" body lift, 2" torsion keys, shock extenders, and 1.5" spacers in the rear on factory escalade wheels with 2" wheel spacers on 35x12.50x17 mud grapplers!it rubbed my valance and It did rub my inner fender plastic rivets (broke them) when I was in a bind while turning but once I stuffed my inner fender behind the lip on my fender (in pic) no more rubbing unless I put it in a pretty big bind!
Y
yukon007
Thanks for all the info guys . Not sure how wide I'm going on wheels yet but looks like that plays a big factor in how high I need to go
JasonW4141
