freeway2590
Hello everybody, I have a 2003 Yukon SLT. I recently installed my Blackbear 91 tune along with my brand new Blackbear dual pin fan harness and brand new dorman electric fans. After getting everything installed, I can't get the fans to cut on at all. When I cut on the AC the fans won't do anything. Today drove the truck for a 1/2 hour and let it sit for 1/2 hour and the temperature gauge finally went past 210 degrees and the fans would not come on. I checked the blue 42 pin and the green 33 pin twice and made sure that they were in the right slots and that they were seated properly. I even attempted to push the pins back out the slots and they would not go up. I triple checked my positive and negative wires. I also hooked the fans up to my battery to make sure they would come on and both fans worked. I don't know anything about relays, so I don't know how to check and see if they are good or bad. I'm thinking either the pins are not turned on or I have a bad relay or relays. I'm all out of ideas, any suggestions on what else I could check would be greatly appreciated.
