Need help with 95 ignition wiring.
Alphamodsquad
Hi everyone im doing something crazy with my 95 since the body rotted to shreds ( lots of salt water boat ramp days) im installing everything into a 66 chevy, im looking to reuse the 66 ignition and would like to wire the newer harness into it. There are couple wires i havnt identified yet and dont see any references i know there is a 2nd batt and ign which i will run a relay off ign 1 to connect them when necessary. I have a small gauge brown/white stripe i haven't identified. I think the brown and the orange are both acc and assume the two small black wires are ground
exp500
You really need to look at the 95 wiring diagram. You should also consider quite a few relays to lessen the load on ignition switch.
Post up W/D pics here if you need help.
A
Alphamodsquad
I downloaded a wiring diagram for the truck but it seems to missing some details, for example there is a tiny push button that is attached to the ignition switch that looks like the key presses it when inserted i assume that is for the buzzer when the door opens, i do plan on running relays and have the ignition activate them. I transferred the entire harness into the 66 so if i can get it to work together I'll be set.
A
Alphamodsquad
Ok i need help identifying certain parts on this column to determine if i need to transfer them to the 66. Can anyone identify these components so i can look them up by name to find out what they do. Is this shift indicator?
On the ignition switch was this little button, is this for key in ignition buzzer?
exp500
Brake Pedal interlock. Just remove the rod. Buzzer under dash.
Full manual here-https://www.tahoeyukonforum.com/threads/helpful-links.131971/#post-1665051
A
Alphamodsquad
Thank you i just found the one and only diagram that describes it. Also that little button is key in ignition i just powered it up and pressed it. Im getting closer to the finish line thank you.
A
Alphamodsquad
I know im a pain in the butt vut i ha e yet to identify these two wires somehow the little brown with white stripe came off something. And the large brown is from ignition but doesn't show power or ground when tested.
exp500
Pull all 3 1995 manuals from the link above. Diagrams in there. The Truck Man is the one you want and the other 2 are differences from truck.
Usually DK Brn are lights/windows. Can't see what harness you are in.
pistolpetem9
