Need help interior door panel '05 Hoe
Raxus
Raxus
Iowa
If you have to pull the door panel yourself, and the window switch is still on the panel (most of the time they are not) then I would carefully pop the switch out of the bezel and leave the switch bezel attached to the door panel. Hopefully they won't try and charge you any extra for the switch bezel. Then you can completely and PROPERLY fix the entire thing for just $35 and gas money!
Bingo Scottyboy! I was thinking the same thing. Hopefully will get it this weekend. Will let you all know how it went :)
Rax
big_b_in_PA
Billy Badass
Central Pa.
Rax
If you can’t find one that’s not broken at the junk yard, I have one from a vehicle I’m parting out. The white tab on the arm rest is still good and I’m pretty sure I still have the switch panel housing as well.
Raxus
Raxus
Iowa
With a ton of thanks to @big_b_in_PA aka Brian, door looks as good as new again! My son help me out too. Was a good father/son time for us. Here is what it looks like now:
Rax
Tupapi
