Mystery plug under center console
mtbennett24
I removed the cup holder and tray to get a look inside of the center console and noticed a plug that was not plugged into anything. See attached pic. Any thoughts on what this might be? I have an '09 Z71 with factory non-Bose radio set up. Thanks!
bryanfeelsgood
Portland, OR
My guess is it's for the amp/sub you don't have. That the location of the stock amp in the Bose equipped NNBS Hoes
M
mtbennett24
That was my guess too. Is the Bose sub that I don't have a powered sub or are the sub and amp separate components?
bryanfeelsgood
Portland, OR
Technically they're separate, but it's not like you would ever want to swap one but not the other. There are guys who have pulled the factory sub and used the amp to power aftermarket stuff, but I'm not sure how well that turns out.
M
mtbennett24
Wondering if this plug could be used for anything. A powered sub? Stealth box? Amp?
gibsonm21
San Diego, CA
I can't see the wire color, but it looks like the wiring harness that plugs into the factory sub that would normally be located under the center console.
bryanfeelsgood
Portland, OR
You'd probably be better off running your own wires for the stealth box. It's ridiculously easy to run wires from behind your head unit to the center console, not really saving yourself that much time/effort by keeping the stock harness.
ranorris2
The Coolest
McKinney, TX
Sorry to bring this thread back to life, but I have this mystery plug too and I have a bose system...so I'm lost on what this plug could be...any thoughts?
vsaravia
