My dim lights will not come on. 2008 Tahoe
jon1440
2008 Tahoe Z71 package if it matters. Recently my dim lights will not come on. Bulbs fuses and relay are all good. Seems like it happened over night. I can get my ambers to come on via the light switch on the dash but no head lights. brights work fine aswell. I did swap out the light switch in the dash but still have the problem. I did change out the battery recently but not sure how that would affect anything else.
Any ideas?
if you mean low beam headlights, then did you check the bulbs? have you checked for 12v on the bulb socket?, checked for ground on the bulb socket?
iLikeEggs
Potato!
Oregon, USA
I had a similar situation on my 2011. High beams came on and stayed on, low beams were out completely. I replaced the turn signal/high beam lever but nothing changed. Turns out it was the round head light switch on the dash to the left of the steering wheel.
Durobans
