Muffler Performance?
MtnDewd
MtnDewd
Northern Colorado
Wow...I thought there was just a handful of mufflers out there. Most of the mufflers shops around here have only mentioned 2 or 3 different options.
Thanks again for all the information.
foreverfalcon40
Stay away from FLOWMASTER! Its been dyno proven on GMFS.com. I can't the thread. But I do remember it.
I understand your POV it "works" SAS. I changed my opinion on works when a wise man told me this...
"work" is a relative term. Stock radio's "work", small **** "work", and so do mediocre looking women, but lets face it...newer/better ones with less miles are always a welcome addition.
bowtiefreak
No Quarter
Near Philly
Sticky that part about the mufflers dyno results! Good info. Borla is also a lifetime warranty. We use them a lot in my family.
road1will
pretty pretty good
Johns Creek, Georgia
i`m not willing to get into a pissing contest about what flows better and what does not. we all like what we like for whatever reason. i`ve never seen dyno proven results on FM vs stock or vs any other muffler.
can you come up with any?
---------- Post added at 03:04 PM ---------- Previous post was at 02:13 PM ----------
well i finally found something. it`s a muffler shootout done on a 90 mustang.
http://www.carforums.net/showthread.php?t=51203
keep in mind that they do not list what exact muffler they use from all brands and different models from any brand could yield different numbers.
and on our mostly low performance trucks it could be a different story on which provides more horsepower. i could care less what flows better and gives more horsepower, i`m just trying to dispell the myth that flowmasters don`t flow at all.
a 7 horsepower difference between the top and bottom isn`t a hell of alot. and a whole 3.4 HP between magnaflow and flowmaster isn`t too impressive seeing that flowmasters don`t flow well as you put it.
Results based on 5.0 Mustang Magazine December 2002 issue (page 55). Test car is a ’90 Coupe with 370 HP and 11 second potential. A number of 66 pulls were made to compile this information. Where does your muffler stack up?
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.****** Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.****** Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.****** Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.****** Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
Not trying to get into a pissing contest, i just stated the obvious. a flow through muffler does flow better than a chambered muffler.
350VortecSSCT
Westport, CT
Overall, A simple Magnaflow Muffler is the best set up...if you do a muffler, and you wanna do flowmaster, upgrade to Magnaflow because it's higher quality in the metal and has a sweeter sound to it...deeper too...If you want loud the whole time either no muffler, straight pipe or just a glass pack...cheap way as well...Or do Bassani, Borla, Magnaflow and others for deep performance but pricey!
coops924
