Misfire on Cylinder #3
satterfieldg
having trouble with my 2002 5.3 mis fire on cylinder #3.
Injector receiving pulse voltage, injector replace, spark plug and wire replaced, coil pack replaced, then swapped out with know working one.
PLS help
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Gotta start with the basics. get a compression reading on that cylinder and #1 and #5 and compare to see if they are reasonably close in compression. You could also have a vacuum leak at that cylinder to check for. What does the old plug look like compared to #1 and #5?
S
satterfieldg
Rookie mistake on noting the plugs while changing. Fixed to work 4 12 hour days so will be next week before I do the compression test.
Was that your ship?
I was on CV-67, JFK, from 79-84.
OR VietVet
Willamette Valley
Yes, that is the USS Kitty Hawk CV-63. I took that pic from a helicopter in the Gulf of Tonkin. I was a ship's company photographer.
TejasPitt
