lq4 vs lq9???
BlizzardX23
Sacramento, California
LQ4 (6.0) in our Denalis
LQ9 (6.0) in the Escalades
LQ9 = 10.1:1 Compression
LQ4 = 9.41:1 Compression
LQ9 has roughly 20more hp due to compression? I believe
LQ4 = still better
BlizzardX23
Because its much stronger, can handle a lot more abuse
LQ4 takes forced induction much better then the LQ9 (Supercharger, Turbo..etc)
LQ4 is cheaper to beef up
BlizzardX23
I just realized I was thinking of the LS2 vs LQ4
LS2 is aluminum, LQ4/LQ9 is Cast Iron
and lots of people say they LQ9 (stock for stock) is stronger..however, like I said..if your planning of FI...the LQ4 will hold up a lot better due to the lower compression..
LQ9 takes premium?
LQ4 takes 87
TheFuzz
Idiot Police
Spurbury, VT
The only real difference is in the pistons and maybe a slight varience on the heads, right?
LQ4 = dished pistons
LQ9 = flat top = slightly higher compression
If I had the choice, I'd still go with the LQ4 if it were me.
Max
Mile High
Denver
Parts are all the same but the compression does help. I believe the LQ9 rods were stronger too but I've seen 800tq out of LQ4s with arp hardware so they're all pretty solid. I'm stoked I have the LQ4 specifically due to the boost friendliness.
blueflamed03
Oklahoma
Lq9 ftw!
---------- Post added at 03:26 PM ---------- Previous post was at 03:02 PM ----------
The 5.3 came in 4 versions, the LM7, LM4, L33 and L59. They had roughly 285-295 HP and 325-335 ft lbs of TQ. Except for the L33, it had around 10-15 more HP.
LQ9 with 10:1 compression, would be sweet driver.
Or, look for a 2007 L76, 6.0 motor.367 HP and 375 ft. lbs of TQ.
Found in 2007 Suburban, Avalanche, Silvarado, Sierra, or Yukon XL.
That would be a great find.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
Lq9 ftw!
well my 06 yukon 5.3 had 295 hp. My 07 yukon xl 5.3 has 320 hp.
blueflamed03
Oklahoma
07 5.3 was LY5, 320 version.
LQ4 is 300 HP and 365 ft lbs TQ.
LQ9 is 10:1 with flattops, 347 HP and 380 ft lbs TQ.
L76 would still be the dominant one to have.
johnsonwillie199
