low side switch???
dans99
Cape Cod
I was going to do the paper clip trick to the AC low pressure switch to figure out why the AC comp. isent coming on, but I was not 100% sure which is the low side switch. Is it the one right behinde the the compressor? Thanks
retorq
Kingman AZ
Put a pressure gauge on the low side service port and see if there is anything in there. You can get cans of recharge with the gauge for just a lil more then the regular cans. Then when you are done you just take the hose/gauge off and keep it for next time.
D
dans99
Cape Cod
well I found the low side to do the paperclip trick. the A/C comp. kicked on, so it should just need a recharge or new low side switch.
briannorris
